Travel and Lodging
TRAVEL
Argonne National Laboratory is about 45 minutes by car from each of the two major Chicago airports, O'Hare and Midway (see map). Limousine service is available from each airport, and major car rental agencies serve both airports. Limo reservations can be made by calling:
- A-1 Limousine 630.833.3788
- United Limousine - 630.969.3865 or 800.331.9037
The map also shows the major roadways serving the Chicago area.
To reach Argonne from O'Hare Airport, drive east (toward Chicago) on Interstate 190 to the exit for Interstate 294 south (toward Indiana). Go south on Interstate 294 to the exit for Interstate 55 south (toward St. Louis); then take the southbound Cass Avenue exit (273A) off Interstate 55. Northgate Road, the entrance to the Laboratory's main gate, is on the right.
From Midway Airport, take Cicero Avenue north to the entrance to Interstate 55 south (toward St. Louis), which will be on your left, then proceed as described above.
LODGING
A block of rooms has been reserved at a special rate for this meeting at the Argonne Guest House, which is located less than a block from the 401/402 conference center. A number of other hotels are located relatively close to Argonne. No special rates have been established for these hotels, and shuttle transportation will not be provided.
Please make your reservation directly with the hotel of your choice.
CONFERENCE HOTEL
In order to guarantee your room, you must contact the Guest House with a credit card. Call toll free 1-800-632-8990 (fax number is 630-739-1000). Cancellation policy is 6:00 pm on the day of arrival. Check-in time is 3:00 pm, check-out time is noon.
The cut-off date for reservations at the special meeting rate is April 19, 2013; the rate is single/$70 or double/$80 plus 6% room occupancy tax. To receive the meeting rate, mention the 2013 APS/CNM/EMC Users Meeting when you make your reservations. If you do not receive confirmation of your e-mail or web request, please follow up by telephone.
Argonne Guest House
9700 South Cass Avenue, Building 460
Argonne, IL 60439
Reservations: 800.632.8990 or 630.739.6000
Fax: 630.739.1000
E-mail: argonne-guest-house@anl.gov
Web form: http://www.anlgh.org/reservations.php
ADDITIONAL HOTELS
There are many local hotels which can be found by a search on Lemont, Illinois. The conference rate does not apply to these hotels. Consult travel guides for further lodging options.
